How to replace serial tag
Posted by Yooper Farmall on October 10, 2013 at 18:35:05 from (71.238.131.85):
My serial tag is in very rough shape and given the tractor is not very original I don"t mind replacing the tag. I"ve gotten a new tag made up and will be seeing my tractor briefly this weekend and wondered what I would need to change it quickly. How do you change the tag? Knock the brass rivet heads off with a chisel, then need to drill the brass out of the cast iron? If so what size bit? Once cast holes cleaned out put on new tag and insert new brass rivets and tap in with hammer? Am I close?
Thanks
YF
