Re: How to replace serial tag
Posted by farmallhal on October 10, 2013 at 19:30:36 from (184.6.111.170):
In Reply to: How to replace serial tag posted by Yooper Farmall on October 10, 2013 at 18:35:05:
On my Farmall 240 the original tag came off by getting a thin metal wedge piece under the original tag with a few light taps next to the existing rivets. The rivets I received with my new tag are drive rivets with a few raised spirals the length of the rivets which are tapped in lightly as you noted. You may have to "tweak" the holes in your new tag a little to match the existing holes in the cast bell housing. Hope this helps, Hal.
