Farmall 300 casting numbers
Posted by MoMike on October 12, 2013 at 05:48:27 from (99.195.209.210):
Checking the numbers on my 300, regarding head issue as posted previously. Engine casting number
362743R2 C169, head casting 361479R1. Do these belong together. I wonder as in the past someone cut the rockershaft oiler tube off and stuck a copper tube from a fitting on the oil filter into the cut end, just shoved it under the valve cover. Found a head on line that has a second hole on the spark plug side between #2 and 3 spark plug, wondering why mine doesn't have it.
Thanks in advance. Thanks to D Slater for his information.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
