Re: Farmall 300 casting numbers
Posted by D Slater on October 12, 2013 at 18:23:41 from (184.14.160.234):
In Reply to: Farmall 300 casting numbers posted by MoMike on October 12, 2013 at 05:48:27:
361479R1 is the original head number for a gasoline 300. Probably can find a date code on top between the head stud holes that are outside the valve cover.
Sounds like someone mistakenly blocked the oil passage to the rocker arms in the head gasket area. Or installed the cam bearing wrong or bearing spun in the bore and blocked the oil passage to the rocker arms.
