The original ground WAS one of the bolts that held the belt pulley assembly. 1/2 - 13 if memory is correct. The original ground was an insulated cable not a strap. Make up your own cable with welding cable or heavy duty battery cable from NAPA. While you are at NAPA get a battery cable lug with a 1/2 hole in it. If you ground to a starter bolt you will need a lug with a 1/2 inch hole as well unless it is a late SM with the three bolt starter.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
