Posted by FBH44 on October 15, 2013 at 23:50:28 from (64.85.215.6):
Bought an old instrument cluster at yard sale, it might be from some locomotive. Has a "Bendix-Westinghouse Air Brake" 1-150# air pressure gage, a "Twin-Disc TorqueConverter" 100F-250F temp gage, and places for a throttle indicator, a water temperature indicator, lights, etc. But is also has a Westberg tachometer labeled "RPM-hundreds", 0-3500 rpm. Has three wires on back, as near as I can see the old masking tape labels read "Ground" and "Coil". Unknown third wire. Any advice, pro or con, where I could hook it up to a 12 volt H, see if it works?? Do NOT want to damage anything, or smoke anything.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
