Re: H Tachometer ??
Posted by Janicholson on October 16, 2013 at 05:30:37 from (199.17.6.25):
In Reply to: H Tachometer ?? posted by FBH44 on October 15, 2013 at 23:50:28:
The third wire is probably the illumination. It could also be the power input to the tach. Look at the cluster and see if there is a general lighting system, or independent bulbs. Jim
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
