Re: super a runs bad when warm
Posted by Janicholson on October 16, 2013 at 18:29:12 from (74.60.94.18):
In Reply to: Re: super a runs bad when warm posted by pork on October 16, 2013 at 17:44:28:
Check the fuel cap for a plugged up vent hole. Even partially plugged will cause the issue. Mu guess is restricted fuel. Running at slower RPM draws much less fuel and it can then keep up.
Put a lawn mower tank on a carpet strapped to the fuel tank. Run a rubber (fuel) hose to the carb (fitting and clamp needed to adapt the line) then run it to see if it stil happens. Jim
