Posted by D Slater on October 18, 2013 at 13:47:23 from (184.14.160.234):
In Reply to: Re: C-169 Production posted by Absent Minded Farmer on October 18, 2013 at 12:44:23:
Yes that's a replacement block number. Fuel pump could be mounted on the carburetor side and the block was drilled behind the plate for a push rod to camshaft. IH also used that block for a SH block replacement. But when used to replace a original SH block it required a different Piston and sleeve set.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
