Packard 56 connectors...need help!
Posted by Dave H (MI) on October 18, 2013 at 14:14:13 from (70.9.80.32):
I am installing the automatic row marker controller in my 1586. The connections look like some Packard 56 connectors I found on line and I need to install a couple on a fused link I am inserting in between the control box and the light harness hookup. None of which matters, but I thought I would mention it.
My question is the procedure for installing these connectors. There is a crimp on metal connector and then a black plastic cover. The covers snap together to lock the connection. Do I put the wire thru the cover before crimping on the connector or do I crimp on the connector and then insert it into the cover? Anyone familiar with these? Thanks!
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
