Re: Packard 56 connectors...need help!
Posted by The tractor vet on October 18, 2013 at 21:16:12 from (75.19.125.100):
In Reply to: Packard 56 connectors...need help! posted by Dave H (MI) on October 18, 2013 at 14:14:13:
I do a lot of 56 Delco stuff and i have the crimper to do it all in one shot . Ya do the end and then they slide into the insultator and lock in . If ya need to take them apart you can make a TOOL out of a cotter pin by just filing it flat on the rounded side and you insert it on the plug in side and that will push the tab down so you can remove it from the insulator , then if you want to put it back in ya just bend the tang back up and stuff it back in. As for fueses i gave up on FUSES years ago i now use self resetting breakers . Each and every tractor i work on a wiring problem the fuses is the first think that gets removed and a breaker is put in place .
Today's Featured Article - An AC Model M Crawler - by Anthony West. Neil Atkins is a man in his late thirties, a mild and patient character who talks fondly of his farming heritage. He farms around a hundred and fifty acres of arable land, in a village called Southam, located just outside Leamington Spa in Warwickshire. The soil is a rich dark brown and is well looked after. unlike some areas in the midlands it is also fairly flat, broken only by hedgerows and the occasional valley and brook. A copse of wildbreaking silver birch and oak trees surround the top si ... [Read Article]
Latest Ad: Variable pulley for case 1530 skid loader [More Ads]
