I should have mentioned that the 12v conversion is pretty old, more than the 20 years I have owned the tractor, but these last 2 instances are the first where the points seem to be getting messed up. The coil has always gotten hot, or at least pretty warm, and I did put in an identical replacement along with both (?) condensers last Spring. It has one condenser in the distributor, and another external one that attaches to the coil bracket. I never understood why it needed 2.
These happened while the alternator had been accidentally disconnected when the tractor was split last Spring. After running on battery only all summer, I noticed it wasn't charging and found the lead (with a diode somewhere in the circuit) back to the ignition was not connected. I repaired that and then found the points burned up again. may not be related, but full disclosure.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
