Re: Cub points problem
Posted by old on October 21, 2013 at 08:49:42 from (209.86.226.57):
In Reply to: Re: Cub points problem posted by beargap on October 21, 2013 at 07:00:01:
Now days most parts are made poorly so if you buying cheap points and condensers that is where your problem is you need a good brand name part. Next 50% of new condensers are bad right out of the box and I have now replaced one in years due to that fact. As for how old the conversion is that does not matter unless you have a shorted ballast resister which is not likely since they burn out instead of shorting out
