Re: IH 1456 Fuel issue?
Posted by CharlieU on October 22, 2013 at 18:08:55 from (199.86.19.63):
In Reply to: IH 1456 Fuel issue? posted by ValleyFarmer on October 22, 2013 at 16:45:36:
I have diagnose this type of problem many times.
Inside of the injection pump there is a plastic washer that holds the governor weight retainer together and it sounds like it is coming apart and plugging up the leak-off connection on the injection pump. To test what is happening I have a little simple test, on the outside of the injection pump there is a small cover that is held on with two small screws. This cover is used for timing the injection pump to the engine. Anyway to test if this retainer is breaking up, start the engine and as it's slowing down, loosen up these two small screws and let the diesel fuel leak out. If the engine speeds back up you found your problem. The injection pump needs rebuilding. Keep us posted to what you find.
