Re: Tracing a wire on my 1586
Posted by Dave H (MI) on October 23, 2013 at 11:35:54 from (173.121.113.1):
In Reply to: Re: Tracing a wire on my 1586 posted by Hugh McKinney on October 23, 2013 at 11:03:59:
Hugh, the wire in question is green and white and located in the right fender where the light connection is. It has a black Packard style connector on it. It exends out of the wire harness loom for the lights a few inches and has nothing connected to it. I am trying to trace the wire harness back to the source and see if I can find this wire and use it to power my control box. I was hoping someone could tell me where this wire might be found on the other end.
I am quite sure the much thicker loom harness going into the fuse box is, in fact the harness I am referring to combined with the left side harness and probably others. There are two wires coming out of this into the fuse box and they both are inserted into the same style (packard) connector as in the fender. Just a little confused about why two wires instead of one since there is not a loose lead in the left fender.
Confused yet? Me too.
