Re: IH 1456 Fuel issue?
Posted by ValleyFarmer on October 23, 2013 at 15:38:07 from (67.234.30.12):
In Reply to: IH 1456 Fuel issue? posted by ValleyFarmer on October 22, 2013 at 16:45:36:
Thanks for the help. I wont get a chance to work on it until Monday. I will update then with what I find.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
