Re: 706 Brake Valve
Posted by mazemeister on October 23, 2013 at 17:36:40 from (69.127.90.15):
In Reply to: 706 Brake Valve posted by boomer22 on October 23, 2013 at 12:36:32:
when you say stuck on, do you mean the brakes drag, or they lock up the wheel enough to skid the tire as you drive it?
if it is locked up solid and you're sure the problem is in the valve, one thing to check is pop off the aluminum cover from the top of the brake valve, and there should be a phillips head screw holding the pistons to each valve spool. see if they are intact and tight. they should be bottomed out.
many years ago i had one of those screws let go of its head and locked up the wheel.
