Re: 706 Brake Valve
Posted by HydroTek on October 23, 2013 at 19:18:08 from (69.27.61.74):
In Reply to: 706 Brake Valve posted by mazemeister on October 23, 2013 at 17:36:40:
Later designs replaced this screw with a larger nut ..if you look how this valve works, this small screw is pulled on each time you push the brake pedal. A large amount of force can be applied to this fastener by a heavy foot on the pedal
anyways ..easy to break the screw
