Re: 12v conversion wiring - Farmall H
Posted by Gerry Powell on October 24, 2013 at 13:50:01 from (173.172.71.204):
In Reply to: 12v conversion wiring - Farmall H posted by Owen Aaland on October 24, 2013 at 09:13:49:
True to a point, but on Farmall tractors, the highest RPM is about 1600 and with a about a 2:1 ratio on the crank/alternator pulley, the max alternator RPM is about 3000 RPM. At these RPMs, the alternator can provide about 60% of it's rated output. For the Hitachi 14255, that is about 30 amps. If the fuse blows, try a 40, but it is not a good idea to run the alternator unfused.
