Re: 12v conversion wiring - Farmall H
Posted by Owen Aaland on October 24, 2013 at 09:13:49 from (216.47.34.210):
In Reply to: 12v conversion wiring - Farmall H posted by Gerry Powell on October 23, 2013 at 16:01:40:
If you are going to put a fuse in the alternator to battery wire it should be at least as large as the maximum alternator output. In this case it would be 50 amps. If you have a 30 amp fuse for an alternator that is capable of producing 50 amps is would be possible to blow the fuse if the battery were low and the engine rpms allowed the alternator to produce the full 50 amps.
