Posted by Fudd on October 24, 2013 at 14:52:34 from (63.228.76.70):
I removed the voltage regulator and found no markings as to what the ground should be. The battery was installed with the neg. to ground. I have unhooked everything in the charging system and the ignition system and still get a 3 volt discharge. I reversed the battery and installed it pos. ground, polarized the VR and started it up and the amp. meter discharged. I then changed everything back and polarized the VR again and started the tractor and the amp. meter showed a charge and it was 9 volts on my meter. I unhooked the pos. cable and I then had a 5 volt drain. So much for progress. Is the light switch on the left side of the instrument panel? There is a switch there that is broken off and a sheet metal screw has been screwed into it. None of the lights come on when I hook the battery up no matter where the switch is. I could not get the throttle lever off to pull the instrument panel so maybe tomorrow with some PB Blaster. I also need to know which hydraulic fluid it takes as it is bone dry. I think I will be bald before I get this one figured out. Thanks
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
