Re: 300 utility full rpm = 1500 not 2200rpm
Posted by VWKarl on October 25, 2013 at 20:22:56 from (207.216.93.179):
In Reply to: 300 utility full rpm = 1500 not 2200rpm posted by VWKarl on October 24, 2013 at 20:49:43:
Thanks for all the great advise . I have started today to source out a governor spring IH 357012r1 here locally with no luck so will have to mail order. The bushings in the governor look good but the spring is very sloppy which seems to explain why the throttle doesn't start to rev until about the 6th notch . There is no slop or play in the throttle linkage as well. I have the same tach as the picture from AJB-830 and the tractor has the IPTO and the T/A
As you can see I have tried to answer all of your questions in this one post.
Thanks again Karl
