Re: Ignition Switch
Posted by caterpillar guy on October 27, 2013 at 05:42:13 from (75.128.156.3):
In Reply to: Ignition Switch posted by Dave8N in Pa on October 26, 2013 at 17:01:13:
With the battery in. There is a push pull switch below the light switch like already said out on in off. With the switch out there is another push button switch up and to the left. It looks like the brass but of a shotgun shell. Push it with the choke out a bit in cooler weather. The choke is at the bottom below the on switch, the rod with a ring on the end. Then of course set the choke to run smooth.
