Re: PICS of Idler pulley on alternator mount on H farmall
Posted by Bob M on December 06, 2000 at 08:20:55 from (192.232.119.194):
In Reply to: PICS of Idler pulley on alternator mount on H farmall posted by wh on December 06, 2000 at 06:15:08:
Nice pix! Looks like you've got the digital camera thing all figured out!
Nice idler installation too. One suggestion however: When using the old generator bracket same as in your photos, I experienced a couple failures (breakage) of the alternator pivot bolt where the rear end of the pivot boss meets the generator bracket. Each failure occurred after about 100 hours of running. Cause was metal fatigue in the pivot bolt due to the alternator vibrating in a vertical axis about the rear of the pivot boss. Solution was to modify bracket so the pivot bolt is supported at BOTH the front and rear of the pivot (same as when the alternator is installed on a car/truck engine). Have not had a pivot bolt break since I made the change.
Post A Followup
: Re: Re: PICS of Idler pulley on alternator mount on H farmall
