IH 674 Air in Hydraulics
Posted by TonyHill on October 28, 2013 at 19:00:31 from (67.158.161.141):
I have read through many of the posts but I cant seem to fix my problem. My hydraulics start failing after about 10 minutes of operating. The pump starts whining and the engine gets loaded when the pump cycles on and off. The oil is smoking hot. I"m guessing the pump dies when it gets to hot.
I have replaced the filter and cleaned the screen a number of times now but the problem always comes back. New oil each time. This is getting expensive. The screen isn"t clogged. I have also loosened the bolt with the spring and valve to bleed the air. Fluid is flowing through the radiator up front... I would like to find a diagram showing all of the Hydraulic parts too.
Thanks for any advice.
