Re: Super m wiring - won't shut off
Posted by clint s on November 02, 2013 at 10:19:19 from (108.183.224.168):
In Reply to: Super m wiring - won't shut off posted by John T on November 02, 2013 at 06:22:00:
I do not have a diode or light on my tractor and it turns off just fine through the switch with my conversion. I have a keyed battery disconnect as it will draw the battery down if I do not disconnect. I have been meaning to rewire everything and do it right.
I would check the wiring
http://www.radioshack.com/product/index.jsp?productId=2036268
I am pretty sure this is the diode you need 1N4001
