In the wire from the coil input or ignition switches IGN terminal (supplies hot voltage to coil when ON) that goes to the small 1R alternators excitation terminal, do as posted below place a diode or else I prefer a 10 ohm 5 watt resistor for some degree of current limiting or else a small 12 volt incandescent indicator lamp.
The alternator can back feed the coil to keep it running even with ign OFF so the diode or resistor or lamp prevents that
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
