Re: Farmall 560 questions
Posted by John G. Hasler on November 03, 2013 at 05:38:46 from (174.124.81.100):
In Reply to: Farmall 560 questions posted by samuel c on November 03, 2013 at 00:29:19:
> It was at top tank seam but could not tell if
> came from above. Is this a real problem or a
> bottle of Stop Leak?
I"d give the Stop Leak a try.
> The loader has a bale grapple. Is the WEE heavy
> enough to handleft 5x6 bales?
I don"t know about the loader but I wouldn"t put that much weight on the front end of a 560. I also doubt that the 560"s feeble hydraulics could handle it.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
