Farmall 560 questions
Posted by samuel c on November 03, 2013 at 00:29:19 from (50.27.215.49):
I am looking at a 560 diesel WFE (SN 35543) to mount a
Farmland f-11 loader. When I shut the engine off I noticed a
wisp of white smoke at radiator and looking through the grill
found front top of radiator was wet (anti-freeze). It was at top
tank seam but could not tell if came from above. Is this a real
problem or a bottle of Stop Leak?
The loader has a bale grapple. Is the WEE heavy enough to
handleft 5x6 bales?
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
