Posted by RustyFarmall on November 03, 2013 at 07:06:24 from (216.248.71.226):
In Reply to: Farmall 560 questions posted by samuel c on November 03, 2013 at 00:29:19:
If the wide front has the 6 bolt hubs instead of the early style cast front hubs, I think you will be okay.
The PTO pump that was furnished with those loaders will generate 1,200 psi. I think the 560 is at, or atleast close to that figure, so it should work.
Just for the record, I am currently in the process of setting up an F11 on my M. So far, I have found that the belly pump WILL make the loader go up and down, but doesn't have the pressure needed to be able to pick up anything of significance. Also, the M currently has ONE set of rear wheel weights, and that is not enough.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
