Re: Ih 300 utility problem.
Posted by Tractorfan1 on November 09, 2013 at 07:41:12 from (99.251.251.61):
In Reply to: Ih 300 utility problem. posted by Janicholson on November 04, 2013 at 16:36:30:
Janicholson said: (quoted from post at 17:36:30 11/04/13) No the hub is splined to the end of the axle. It can be loose and wear at that point. It is easy to remove the bic centered bolt and washer, then slide the wheel/hub off the axle. Put cribbing under the housing to assure no falling, then if it has no liquid in it it should be able to be pulled off. (two people are a good idea, or a cherry picker to hold the weight)
If it is very difficult to remove, the splines and hub might be OK. If easy and loose, it may need to have a good used axle put in as well as bearings and a good used hub. Jim
I took the wheel off this morning, the hub slid off with no effort at all. The axle splines look good to me, but I have included a couple pictures and a video of the hub play. Does it look like I can get by with a hub, or should I replace the axle as well? TIA
third party image
third party image
third party imagehttp://youtu.be/Yx2mTxAVwjM
This post was edited by Tractorfan1 at 16:12:42 11/09/13.
