No the hub is splined to the end of the axle. It can be loose and wear at that point. It is easy to remove the bic centered bolt and washer, then slide the wheel/hub off the axle. Put cribbing under the housing to assure no falling, then if it has no liquid in it it should be able to be pulled off. (two people are a good idea, or a cherry picker to hold the weight) If it is very difficult to remove, the splines and hub might be OK. If easy and loose, it may need to have a good used axle put in as well as bearings and a good used hub. Jim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
