Re: Weak spark question
Posted by old on November 09, 2013 at 13:03:49 from (209.86.226.11):
In Reply to: Weak spark question posted by Zachary Hoyt on November 09, 2013 at 11:07:03:
6 or 12 volts the problem can be different between the 2. If 12 volts maybe the ballast resister if you have one is going bad which would cause odd problems. If 6 volts or 12 volt maybe the ignition switch is going bad. Me I almost never replace condensers any more due to them being bad right out of the box. I would hot wire it and see if that helps your sprak. If it helps and you have a blue/white spark that jumps a 1/4 inch gap when hot wired the problem if from the coil back
