Weak spark question
Posted by Zachary Hoyt on November 09, 2013 at 11:07:03 from (184.10.222.196):
I am having a weak spark problem with my 300. If I take the coil
wire off the cap and hold it next to the brass colored adapter
where the temperature sender screws in it will make a small
yellowish looking spark. I cleaned the points and they seem to
be opening and closing correctly. I am thinking that this may
mean that the coil or the condenser is weak. I put a new
condenser in when I got the tractor running in summer 2012, in
the fall it wouldn't spark and I put the old condenser in again
which seemed to fix the problem. I then bought condenser and
points from NAPA and put them in, the points were much better
than the ebay ones I had in it but the new condenser wouldn't
work and I had to again put the old one back in. Any advice as
to what I should do next will be much appreciated. I wouldn't
mind putting in electronic ignition if that would be better, or if
there is a source for a condenser that might work that would be
great to know. I can get a coil at NAPA that seems to work fine,
so if that is what I need that is no problem. Thank you for taking
time to read this.
Zach
Today's Featured Article - When Push Comes to Shove - by Dave Patterson. When I was a “kid” (still am to a deree) about two I guess, my parents couldn’t find me one day. They were horrified (we lived by the railroad), my mother thought the worst: "He’s been run over by a train, he’s gone forever!" Where did they find me? Perched up on the seat of the tractor. I’d probably plowed about 3000 acres (in my head anyway) by the time they found me. This is where my love for tractors started and has only gotten worse in my tender 50 yrs on this “green planet”. I’m par ... [Read Article]
