Re: Weak spark question
Posted by Janicholson on November 09, 2013 at 13:16:39 from (199.17.6.25):
In Reply to: Weak spark question posted by Zachary Hoyt on November 09, 2013 at 11:07:03:
I tend to want you to clean and gap the points, if no joy, replace the condenser. Echlin from NAPA seem good
If no Joy a new coil is next.
THis assumes you have solid voltage at the coil from the switch, or resistor. Jim
