Posted by pete 23 on November 09, 2013 at 13:27:41 from (74.33.75.51):
In Reply to: Weak spark question posted by Zachary Hoyt on November 09, 2013 at 11:07:03:
When trying to determine if coil or condenser is at fault, the first thing you do is eliminate the points. By that I mean, either turn engine to where points are open or block them open with a piece of paper or some clean insulation of some sort. This way you don't have to be concerned about points being part of the problem. With points open, switch on, jump distributor side of coil to a good ground with what ever you have handy. A nice short jumper wire works good or a screwdriver will work. Then just make and break contact with your jumper while holding high tension coil wire about quarter inch from a good clean ground. This will tell you if you have a good spark. If you do not, then suspect feed to coil, coil itself or condenser. If you do get a good spark that way, then turn the engine to the point where you can open and close the points by turning the rotor back and forth. If you have less spark you know points are culprit. Also note, you WILL GET a yellowish spark if you spark to a dirty part like paint or grease. Ohm meters, test lights, jumper leads are your friends while checking for ignition spark.
Also, when opening and closing points with rotor, while holding coil wire near or on good ground, you should have very little if any spark at the points. The main reason for the condenser is to prevent the building voltage from causing and arc at points and wasting the stored energy in the coil by causing a sudden collapse of the magnetic field in coil. Pet peeve of mine is people looking for spark at points.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
