Hi willie, this is the schematic I used when I rewired the system before new paint, using dist. ignition. And like I said before, everything worked just fine. The lights worked, the switch worked and it would make the ampmeter react depending on which position the switch was turned to. And even after 'no lights', the ampmeter would still react depending on which postion the switch was turned to.
This is the schematic that I'm using now, and as you can see, the charging system is the same on both. The ignition switch is what sets them apart, obviously.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
