Re: No Ammeter Movement-No Charge?
Posted by The Red on December 07, 2000 at 10:27:18 from (206.246.187.2):
In Reply to: No Ammeter Movement-No Charge? posted by David A on December 07, 2000 at 10:17:37:
David you should get around a 10 amp charge or thereabouts. It may be the points on the voltage regulator aren't closing or the generator may need to be reworked.
When you pull the coil switch on, you should see the needle move into the negative a bit. If not, it might possibly not be wired up.
Post A Followup
: Re: Re: No Ammeter Movement-No Charge?
Today's Featured Article - Memories of an IH Super A When I was ? up to 10, I worked on my Papaw's farm in Greeneville, TN every summer. As I grew older (7), it was the thrill of my day to ride or drive on the tractor. My Papaw had a 1954 IH Super A that he bought to replace a Cub. My Papaw raised "baccer" (tobacco) and corn with the Super A, but the fondest memory was of the sawmill. He owned a small sawmill for sawing "baccer" sticks. The Super A was the powerplant. When I was old enough (7 or 8), I would get up early and be dressed to ... [Read Article]
Latest Ad: Variable pulley for case 1530 skid loader [More Ads]
