Re: No Ammeter Movement-No Charge?
Posted by Red Dave on December 07, 2000 at 10:52:46 from (208.165.46.34):
In Reply to: No Ammeter Movement-No Charge? posted by David A on December 07, 2000 at 10:17:37:
If everything is working as per original, yes the ammeter should move the charge side when the tractor is running. How many amps it will charge is another matter. It should be 2 or 3 amps on low charge and 9 to 11 on high. If a previous owner fiddled with the wiring, it may not be charging or charging and the meter doesn't show it. If you have a digital volt meter, check battery volts before you start the tractor, then with it running, it should be 1 or 2 volts higher when running if it is charging. I suggest you get a shop manual and go over the wiring diagram to see how yours compares to original. I've seen some strange "modifications" done. I don't think you have a voltage regulator. You probably have a cutout relay in that little box on the generator. Gently clean the contact on that before you get too deep. Leave the cover off, start the tractor and tap the relay armature with your finger to make it close and see if the ammeter picks up. I've had generators where thats all it took. On this forum, Bob M is pretty sharp on the electrical stuff, maybe he has some other ideas that could help you.
Post A Followup
: Re: Re: No Ammeter Movement-No Charge?
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
