New starter on 140 won't turn over.
Posted by Brian Garretson on November 10, 2013 at 12:25:06 from (184.6.32.193):
I have bought a new starter for my 1960 140. The teeth on the old one were pretty much toast. I took the switch off the old starter and put it on the new starter, pressed the push button switch and nothing happened(the starter was not mounted yet). I tried mounting the starter to see if it needed to be grounded but still nothing. I tried remounting the switch to the old starter after a few tries the starter turned over(again not mounted to the tractor). The starter was the original 6v while the rest of the tractor had been converted to 12v. The new starter is also a 6v. I"ve sanded down the contacts in the starter switch and it seems like it should make good contact.
I"m not real sure were to go from here.
any thoughts
Brian
