Re: New starter on 140 won't turn over.
Posted by Tom Fleming on November 10, 2013 at 12:28:38 from (67.20.233.75):
In Reply to: New starter on 140 won't turn over. posted by Brian Garretson on November 10, 2013 at 12:25:06:
well, the quickest bench test you can do requires a battery and a set of jumper cables. Mount the starter in a vice, and clip one lead to the vice. Take the other lead, and with the starter switch removed touch it to the post. it will either run or it won't. Now, that won't diag all things, but it is the first test I run with an unknown condition starter.
This post was edited by Tom Fleming at 12:53:04 11/10/13.
