Re: No Ammeter Movement-No Charge?
Posted by Bob M on December 07, 2000 at 12:24:49 from (192.232.119.194):
In Reply to: No Ammeter Movement-No Charge? posted by David A on December 07, 2000 at 10:17:37:
David - Good chance your ammeter has a stuck needle - especially if the glass is cracked letting moisture get in. I've seen it happen a lot. You are however correct the ammeter shunt will still pass charging current even if the glass is busted and the needle is stuck.
If you have an accurate voltmeter, charging system testing is straightforward: Take a reading across the battery terminals with the engine stopped. Should show about 6.4 volts if the battery is charged. Now start the motor, run it at max throttle and read the voltmeter again. If it reads higher than the first reading, the battery's being charged. If the voltmeter reading is unchanged or lower you've got other problems - bad generator, cutout, wiring, etc.
Good luck! Bob M
Post A Followup
: Re: Re: No Ammeter Movement-No Charge?
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
