Re: Magmeto drive coupling timing
Posted by D Slater on November 11, 2013 at 04:53:04 from (184.14.177.214):
In Reply to: Re: Magmeto drive coupling timing posted by Patrick HMD on November 10, 2013 at 18:23:14:
Patrick, with the engine set at TDC compression stroke. See if you can find the dot or mark on the ignition drive gear. Sorry I don't remember the exact clock position for the slot. Anyway install the ignition drive in putting the gear mark toward where the center of camshaft would be. Some guesswork with the front engine cover on. May have to pull the ignition drive out and move it a tooth or two if at first you don't succeed.
