Re: Magmeto drive coupling timing
Posted by Patrick HMD on November 11, 2013 at 18:10:37 from (75.9.219.30):
In Reply to: Re: Magmeto drive coupling timing posted by D Slater on November 11, 2013 at 04:53:04:
Hiya Dave. Hows it going my friend. Good communicating with you again. I took your advice and everything worked out OK. The gear did have the dots you mentioned. The slots came out at about 2 o' clock first try, but not quite enough room for adjustment. Took it out and scooted it over a bit and the slots ended up at about 2:30. That seemed to do the trick. I was able to get those impulse 'clicks' as per the directions in the owner's manual. I'm going to give it my first try at starting it tomorrow. Wish me luck. There's still a few loose ends I need to tidy up first.
Here's a picture of the hood you sold me at RPRU this last June. It came out just as I expected. As you can see it was truly a diamond in the rough. Got those new tires mounted too, and they look awesome.
[URL=http://s313.photobucket.com/user/bib44wcf/media/a4f396c6-99bd-43ce-8882-1af640c19c1c_zps1c1d65d4.jpg.html]third party image[/URL]
Thanks and best regards
Patrick
'49M
