Re: Starting something with Charlie U
Posted by mkirsch on November 11, 2013 at 06:01:15 from (64.80.110.75):
In Reply to: Starting something with Charlie U posted by cleddy on November 09, 2013 at 16:34:18:
Sometimes they will put out enough to keep the battery charged.
Definitely change out the light bulbs. Running them on 12V in the dim setting is hard on the resistor in the light switch. I think if it burns out the bulbs will go to full 12V and then PIFF!
