another Cub question
Posted by charlie M on November 16, 2013 at 09:15:04 from (173.85.162.59):
Still trying to decide what I have with our 47 Cub at our local railroad museum. I checked the compression on each cylinder this morning, cranking it with a 12 V battery. I have one cylinder at 75psi, two at 50 psi that goes up 10 if I put a little oil in the cylinder and one that reads 0 and goes up to 25psi when I put oil in the cylinder. My 1st question is what should I get for readings and second is the change I'm seeing normal when I add some oil or is it a sign the rings are bad. Valves are all moving so a stuck valve isn't the problem.
