Posted by Janicholson on November 16, 2013 at 09:52:17 from (74.60.94.18):
In Reply to: another Cub question posted by charlie M on November 16, 2013 at 09:15:04:
Great question. If the tractor has been sitting for more than a year or so the valves may have pieces of rust or flakes of trash material under them. I would suggest that the engine should be pulled in a parking lot at 4-5 mph in road gear for at least 1/4 mile before condeming anything. Cubs often have difficulty building oil pressure after sitting due to the pump being in the block casting, and above the oil level. I would pressurize the oiling oiling system with a pump oil can, and a small rubber hose to connect it into the oil gallery at the filter housing (1/8" pipe plug, probably hex key) If it shows oil pressure all is well. After pulling it then check the pressure, if as bad then, it will need to have the head pulled off, and looked at for possible burnt valves and bblown head gasket. The rings may be stuck causing the 50# numbers. If the Zero psi cylinder comes back to 50 or above, I would get it started before tearing it down. Jim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
