Re: 200 Coil Question
Posted by Janicholson on November 20, 2013 at 16:57:16 from (74.60.94.18):
In Reply to: 200 Coil Question posted by LMack on November 20, 2013 at 15:10:01:
To be sure what you mean, I reply: The cranking of an engine is either by an actual hand crank, or the spinning of the engine using the starter motor. Cranking is turning it so it will start. Firing, running, sputtering and backfiring all can happen while cranking. With respect, Jim
