Posted by gene bender on November 20, 2013 at 18:20:50 from (207.177.56.213):
In Reply to: 200 Coil Question posted by LMack on November 20, 2013 at 15:10:01:
Like teddy52 says clean the points easy for them to get a film setting around thats the first thing coils dont go bad setting around clean the points and see it then there is fire there.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
