Posted by mkirsch on November 21, 2013 at 06:54:17 from (64.80.110.74):
In Reply to: 200 Coil Question posted by GarryinNC on November 20, 2013 at 17:09:22:
Technically, "crank" is still the act of driving the engine's moving parts with the starter motor, or a hand crank in that context. "Start" is the IMPLIED desired result.
"Crank" and "turn over" are often (incorrectly) used interchangeably with "start." That works in a non-technical context, where people know what you mean.
We're working in a VERY technical context here, so you need to be CRYSTAL CLEAR in what you mean so that everyone is speaking the same language and can offer useful help.
It does no good to clean the points or check for voltage at the coil, if the engine doesn't crank/turn over with the starter.
It does no good to charge the battery and clean the cable connections if the engine is cranking just fine, but will not START.
Someone who hasn't learned this stuff yet will not understand that one has nothing to do with the other, and will waste hours tinkering with the ignition when they really need to clean the battery cables or look at the starter motor itself, or vice versa.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
